05 Excursion oil in water...Long - Ford Powerstroke Diesel Forum
Old 07-03-2011, 01:07 AM
Well I just bought an Eddie Bauer Excursion. I had to drive 400 miles to get this thing and its a beautiful truck. I have an 03 F-250 and I have never had a problem with the truck and it has 125,000 on it. The Excursion has 95,000 on it. So I checked it out before I bought it( I have owned it since Tuesday of last week)but I can kick myself in the ars for not doing a better job. The degas bottle was low on water when I saw it and I told the guys to top it off. I finally get this thing home after driving 6 hours and the next day I find oil in the water. It's not severe like puking out the degas bottle, it's just a little mixed in the system. So I figure its the oil cooler as in most cases. After removing the intake and the 1 million connectors I start to pull of the oil cooler and under the base plate I find the culprit. The oil cooler is fine and so is the egr cooler. The bottom of the oil cooler housing has an o-ring gasket that seals it to the block. The part failed in between the water jacket and oil bath for the cooler. I took some pictures and will post soon. I went ahead and am installing an egr delete with a new oil cooler. The people that sold it say it happened to me on the way but the pictures I have disagree. There was antifreeze in the truck but since oil floats all the goop was uptop. I guess you live and learn. For me it's always the hard way.....Oh did I mention I craked myself in the head with the intercooler pipe trying to get it off...yes it still hurts. 6.0 diesels suck to work on. I think Im going to invest in one of those creepers that hang over the truck!
Old 07-03-2011, 05:28 AM
Slacker
Feedback Score: 4 reviews
MAN, talk about a rough spot. I'm still over picturing you smacking yourself in the head with the intercooler pipe. Sorry, I'm sure it doesn't make you feel better but there are several of us that have done something like that...
Glad to hear that it isn't anything big or severe, since that oil can get in to the coolant passages and be in there for years...
Get the topside creeper and I can't wait to see the pics... BTW, my coolant is about 1/2" below the minimum mark since anything more and my engine likes to push it back out. Just something to consider.
Old 07-04-2011, 04:52 PM
Ok I got all the parts clean and am waiting on parts. When I put it all back together do I need to put some oil in the bath that the cooler sits in? Kinda like priming it? I will not put much at all in there because I dont want oil level to rise and get under clean gasket surface.... Do I turn truck over untill oil pressure builds and then start it? I can pull a fuse so it wont run I suppose.
Old 07-05-2011, 03:32 AM
information regurgitator
Before lowering the oil cooler body into the cavity, yes, dump 0.9 quarts or so in the HPOP reservoir.
Make darn sure that area is surgically clean and that there is a new screen over the HPOP reservoir.
It should fire up with a crank time of less than 20 seconds.
