14 dtcs,a new record? - Ford Powerstroke Diesel Forum
Old 07-02-2011, 04:24 PM
1102 mass air low
0261 #1circut low,0264 #2circut low,0267 #3circut low,0270#4circut low,0273#5circut low,0276#6circut low, 0278 #6 balance fault ,0279#7circut low,0282#8circut low,0611 FICM PERFOMANCE,
0673,76,78 #3,6,8glowplugs
Looks like a call to swamps but what about the balance fault?
Old 07-02-2011, 04:55 PM
information regurgitator
I wouldn't worry too much about the balance fault code, unless it returns with the new FICM
Old 07-02-2011, 05:03 PM
x2 on the FICM. Fix that and every thing else will probably go away. Have you checked your FICM voltage?
This would also be a good time to load test your batteries and alternator. Don't want to screw up a brand new FICM.
Old 07-02-2011, 05:25 PM
Powerstroke Techie
x3 Replace the FICM, first and foremost. The P06** glow plug circuit DTCs will likely require either the GPCM or the corresponding glow plugs, along with two new glow plug harnesses (since removal will damage them with 95% certainty).
