Alternator? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-02-2011, 02:34 PM Thread Starter
06kngrnch84's Avatar
Alternator?
Ok, so just last week I was on here with a problem, come to find it was a dummy plug. On to my new problem, seems like that's all this truck is, is problems!! Thursday night I replaced my passenger side dummy plug, hooked everything back up, and fired it right up. Let the truck run for about 15 to 20 mins then drove it around the block, 10 to 15 miles, to let the engine warm up so I could test my no hot start problem. I got about half way around the block and everything started going dim on the inside, truck was running fine. Made it back home, turned truck off and tried to recrank, no luck! Check my batteries, they were both down to about 40 percent. Charged them up, next morning I drove to work, about 50 miles and no problems except battery light was on. Got to work turned truck off, fired right back up. After 8 hours of work, fired up again, went to bank shut it off, when in for about 5 mins, come back out, nothin. Sat for about ten minutes then fired up, slowly. Headed home and went dead on me about 15 into the trip while driving down the road. Left truck there took batteries out got them home and charged them, went back this mornin put them in and no problems, just battery light. Took alternator off today, takin it to autozone to get tested. Just curious to see what u guys think? Alternator or something else?
Thanks
Jackson, MS. 2006 Ford F-350 SRW King Ranch FX4 Crew Cab, All Stock, 160,000 miles
EGR Delete
Updated HPOP Fitting
Updated Standpipes and Dummy Plugs
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
'04 Metal Cold Side CAC Tube
06kngrnch84 is offline
post #2 of 6 Old 07-02-2011, 02:58 PM
DEESLVRGN's Avatar
I'm not much into this subject, I have read everywhere on here that you can't go cheap on your batteries....
I've had my truck since mid December, and literally as soon as I fix 1 thing another completely unrelated part brakes, I'm gonna have a brand new truck here shortly
2006 F350 CC LB SRW 4X4
-Goose Neck
-updated STC, Dummy Plugs, standpipes, oil feed line, "Blue" fuel pressure spring
-SCT Livewire TS w/Pyro "Looney Tuned"
-RECON smoked clearance lights, black OEM grill
-Kitty and Muffler delete
-POWERMAX TURBO
-58V FICM from QuickTricks
-Huge WISHLIST
DEESLVRGN is offline
post #3 of 6 Old 07-02-2011, 05:33 PM Thread Starter
I'm right there with u man. I love this truck, the look of it, the ride, I like the power that it has, and I like the motor when its running. I've had mine about a year and I'm sick of repairing it. After dropping about 1500 on it at a repair shop within the first 3 months of having it, I had to start takin matters into my own hands. Anyway I got Alternator tested, its shot, probably goin to check on gettin it rebuilt Tuesday. Batteries tested too, they r good, and I dont go cheap on batteries either, got the most expensive ones that Oriellys carrys
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #4 of 6 Old 07-02-2011, 05:39 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
bad batteries are a quick way to destroy your ficm. Replace the batteries, and make sure the alternator/charging system is in working order! Good luck.
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
post #5 of 6 Old 07-03-2011, 10:10 AM Thread Starter
Still goin to check on getting my Alternator rebuilt. But I have checked on a new one too. I was told there r 3 different ones for my truck, 110, 120, and 140 amps. I believe it has a 140 on it? And I believe it is the original one, but what do I guys think is the best to go with?
EGR Delete
ELC Coolant
Coolant Filter
Scan Gauge II
New Oil Cooler
Blue Spring Kit
post #6 of 6 Old 07-03-2011, 03:18 PM
As far as size, don't go with anything smaller than what's on it now. If you have or plan to have more electrical accessories you should really consider stepping up the size.
For a manufacturer, stay OEM or try these guys. https://www.dcpowerinc.com/
Whatever you do, stay away from the cheapo auto parts store alternators.
dieselmac is offline
