is my ford ****tin the bed? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-30-2011, 10:18 PM Thread Starter
Okay... so was driving the 6.0 back from the lake today she was runnin all dandy and i slowed down to go over a cattle guard and noticed that it was running kind of rough.. so i kept an ear open and just putted er back home it was about a 20 minute drive and as i got home she was running a little bit more rough, not to the point where its gunna die but i mean still pretty rough. The check engine light had just come on so i shut her off. whats the deal with this ? its not hard starting, i fired it up 10 min later and she fired up fine but still ran rough. Is this the egr valve stuck open? its not smoking white or blue, the coolant is just fine and i do all my regular work on it, just had the oil changed and full coolant flush. Could someone help i have warrenty but i cut my cat and muffler out and would rather not deal with a dealership right now. Thanks guys
ryans6.0 is offline
post #2 of 19 Old 06-30-2011, 10:52 PM
at0075's Avatar
Do you have a fuel pressure gauge? Try checking that and try pulling your egr to inspect. It wouldn't hott to clean it anyways. See if its moving freely and clean with carb cleaner. And look down in there to see if its wet. Should be dry.
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #3 of 19 Old 06-30-2011, 11:00 PM Thread Starter
Ya I have a fuel pressure gauge. All is good fuel pressure wise. I think the egr valve is stuck I'm going to clean it tomo. Can a plugged up turbo cause this as well? I don't put my foot I'n the floor to often, I'm kinda scared to break something haha. I've only had the truck for about 2 months
ryans6.0 is offline
post #4 of 19 Old 06-30-2011, 11:14 PM
at0075's Avatar
I'm not sure if that would make it idle rough when your not boosting ??? And actually its good to get down on it every so often it blows it out keep it clean and 6.0 s hate to be idled. Try your egr and post why you find. Kind of a biotch to get out sometimes lol
at0075 is offline
post #5 of 19 Old 06-30-2011, 11:29 PM Thread Starter
Ya well funny thing is it was Idleing alot right before it started. **** I didn't know that. Well i will take a look tomo. Would an injector cause this? It doesn't seem like miss fireing
ryans6.0 is offline
post #6 of 19 Old 07-01-2011, 08:07 AM
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
Send a message via AIM to MPTonyT
What does it mean if its a little wet in there? I remember a buddies being wet in there when we pulled his EGR valve to clean it.
2005 Ford F-250 CCSB-Lariat-FX4-SRW
SCT - Tunned By Matt @ GearHead Performance
FICM Tuned by Bill @ Power Hungry Performance
AutoMeter Gauge Kit (Boost, Pyro, & Trans)
Diesel Site Coolant Filtration System
Viper 5901 Remote Start / Alarm
Zoodad mod w/ Stealth Screen
4" MBRP Exhaust
MECP Master Mobile Audio/Video/Security Installer/ ASE A6 Certified
MPTonyT is offline
post #7 of 19 Old 07-01-2011, 08:24 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Feedback Score: 4 reviews
Could be the early signs of an EGR cooler failure. It's either going to be slightly oily (CCV, which is totally normal), dry and sooty (what you should expect) or sooty wet coolant (which is a bad EGR cooler).
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 19 Old 07-01-2011, 02:03 PM
at0075's Avatar
at0075 is offline
post #9 of 19 Old 07-01-2011, 05:37 PM Thread Starter
Okay so cleaned the egr. Which was just absolutely caked. And it still runs bad. It's chugs and shakes. It is also down on power a bit. I'm thinking it's an injector. But what's weird is it doesn't have any trouble starting cold. At all. And it doesn't smoke blue. Also is my truck supposed to smoke black stock? It's not a lot but it does smoke. Could someone help! Dang it's driving me nuts. Happy 4th of July weekend to all you americans. !! It's Canada day today here !
ryans6.0 is offline
post #10 of 19 Old 07-01-2011, 05:46 PM
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
sounds like an egr thats what my bosses truck did when his egr went
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
