Misfire all cyclinders
Yesterday my 04 6.0 started to smoke (dark). Today I connected my AutoEnginuity. found that I'm misfiring on all cyclinders. No check engine light. 140K plus miles, have had the truck since 52K. I haven't check the glow plugs. Is it time?
Possibly bad ficm.Thats electronic and fires all the cylinders.Check your voltages and see what comes up.I sold two today at work here so far and its 12:30 now.
Yes, its time to check your ficm voltage output. You could also have low fuel pressure or a high pressure oil leak also. If you got a code for all 8 injectors then you need an FICM or reseat the plug. Does it run better when warmed up? Any hot starting or long crank time problems?
