Edge codes?! - Ford Powerstroke Diesel Forum
Old 06-30-2011, 01:06 AM
Edge codes?!
Edge Evolution gave the following error codes:
P0480: Cooling Fan 1 Ctrl Circ Error
P0520: Fan Speed ​​Sebsor Circ No Signal
P2285: Injector Ctrl Press Sensor Circ Low
What are these meinaa and can affect a visit to unevenness in the cold?
Today FICM demolished and the wiring checked (OK)
2004 6.0 Power Stroke was the vehicle
Old 06-30-2011, 06:26 AM
information regurgitator
Sounds like you need to plug your fan in. If it is plugged in, check the wiring harness.
If you are having problems with the vehicle not running smooth, replace the ICP.
Old 06-30-2011, 10:54 PM
Add tags this morning:
P0401: Exhaust Gas Recirculation Flow Detected Insuff
P0299: T / S Charger Underboost
Is the charger to be in need of renewal, or broken?
The car is fitted with EGR delete kit, but what that error means the EGF?
Thanks again guys
