Next Fix, Need help - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-26-2011, 06:30 PM Thread Starter
Paul04_619's Avatar
Next Fix, Need help
I have just replaced my oil cooler, installed a egr delete, flushed my coolant, and installed a coolant filter. I feel like i am getting close to the 6.0 of my dreams haha. What should i adress next? From what i have read fuel pressure should be my next project. Would a regulator spring solve the issue? Where should i get one?
Paul04_619 is offline
post #2 of 13 Old 06-26-2011, 06:32 PM
majek5's Avatar
Get the kit from Ford. It is the blue spring. Yes it should do the trick, but without gauges, you will not know. The kit # is 3C3Z-9T517-AG.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #3 of 13 Old 06-27-2011, 07:16 PM Thread Starter
Paul04_619's Avatar
ok, il get right on that, how neccessary are banjo bolts?
post #4 of 13 Old 06-27-2011, 08:42 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Truthfully, not very. No change at all, Gain zero.
Instead of the $52 3C3Z-9T517-AG number for the updated fuel pressure regulator spring, order the cheaper 6E7Z-9C165-B which is a different kit, but it still comes with everything you need (minus the cover you don't need) for somewhere around 38 bucks.
Oh, and, one question. Got gauges on there yet?
Check the link in my sig for "basic info for the 6.0 owner" for a good explanation.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 13 Old 06-28-2011, 03:19 PM Thread Starter
Paul04_619's Avatar
No i dont have gauges yet, just thought id jump on the issue while my trucks down with the oil cooler getting changed, trying to kill all kinds of birds with a fistfull of stones and an empty wallet
post #6 of 13 Old 06-28-2011, 03:50 PM
NYC F-350's Avatar
Quoted: 51 Post(s)
Theres an electronic gauge set that is not all that expensive and is a very capable piece.
The scangauge2 can access all the factory PID's and is useful with some diagnosis. For a scant $165, it is tough to beat at the price.
If you just can't swing it yet, keep it in mind. You can get it at most auto parts stores.
Please
post #7 of 13 Old 06-29-2011, 04:36 PM Thread Starter
Paul04_619's Avatar
I misread your question bud, i thought you were asking if I had a fuel pressure gauge, I do have an SCT Livewire with EGT kit.
post #8 of 13 Old 07-05-2011, 07:23 PM Thread Starter
Paul04_619's Avatar
NYC, I cannot find the kit without the housing on Tousleys website... Also would you recommend doing a spring before fuel pressure gauge? I cant afford the gauge right now.
post #9 of 13 Old 07-06-2011, 01:57 AM
NYC F-350's Avatar
Quoted: 51 Post(s)
Just call and use the part number from above. 800-328-9552
Please
post #10 of 13 Old 07-13-2011, 03:03 PM Thread Starter
Paul04_619's Avatar
Thanks NYC, your a huge help. Also recently i have been getting a slight surge, usually when im goin uphill and always at half to full throttle. It happens at around 2000rpm and the tac goes up about 500-800rpm and then immediately returns to normal pull. Any ideas?
