FICM problem or what?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-25-2011, 07:44 AM Thread Starter
I have a 2005 6.0 with intake and exhaust only (turbo down) and the engine light keeps tripping on. the codes that come up are the same ones:
P0264-cylinder 2 injector circut low
P0267-cylinder 3 injector circut low
C342D/C3064-manufcture control
P0055 H02S heater resistance bank 1 sensor 3
not much comes up when the codes are googled, my guess is wiring harness??
I erase the codes, usually 16 or so, repeats, then it pops back on, anywhere between 10 to 100 miles.
any help here??
thanks.
darrkkstarr is offline
post #2 of 4 Old 06-25-2011, 01:08 PM
mike 6.0's Avatar
What is the voltage on your ficm? Mine took a crap this weekend was 48v now 45-48v with a low of 43. Swamps here we come.
mike 6.0 is offline
post #3 of 4 Old 06-25-2011, 02:14 PM Thread Starter
48 without cranking, then 46-48 cranking.
how would you know if its the FICM and not the wire harness//
post #4 of 4 Old 06-26-2011, 01:27 AM
Send a message via AIM to PowerstrokeTech82787
if you wiggle the injector harness for the injectors in question and the codes come back immediatley its the injector harness.
PowerstrokeTech82787 is offline
