EGR Delete and Oil Cooler parts list - Ford Powerstroke Diesel Forum
Old 06-24-2011, 06:02 PM
I'm fixing to install an EGR delete and oil cooler and I was hoping that someone here could tell me what else I should do while I'm in there. I will be doing a thorough flush before I start.
Old 06-24-2011, 06:37 PM
information regurgitator
You need:
4 gallons of a CAT EC-1 ELC coolant
turbo mounting hardware kit
look at your turbo oil supply line (the one that attaches to the top of the turbo). If you see a stainless steel section in the line for a flex joint, buy the new style turbo oil supply line
You MIGHT need intake gaskets (they are re-useable, but if they are original, you might want to replace)
Oil cooler service kit
You MIGHT want to split the turbo and clean out the exhaust side of it.
Part numbers off the top of my head:
3C3Z-6A642-CA oil cooler kit
3C3Z-9T514-AD turbo mounting hardware kit
3C3Z-9439-AA intake manifold gasket (sold each, order 2)
4C4Z-9V424-AA turbo cleaning kit if you so choose to do this at this time
3C3Z-9T516-A turbo oil supply line
3C3Z-8575-AA Thermostat with housing, without housing will be cheaper, ask about it
3C3Z-9T517-AG Fuel Pump Regulator Kit
I highly suggest calling Tousley Ford for all of this. Best pricing you will find. 800-328-9552
Old 06-25-2011, 07:18 AM
Thank you for your help.
