Thank you Powerstroke.org forums!!
I just want to thank the users here. I had a problem with the throttle dropping to idle out of the blue and also running inconsistently. I had respnded on a thread by Time2Live about similar issues. He and Trdltly both found that the wiring harness for the FICM (Passenger side engine compartment) was causing issues. I duplicated it as well. There is obviously a problem with the design. I'm not sure at this point if I should change the harness out or just work with the one I have.
These guys saved me probably thousands of dollars of swaptronics maintenance I probably would have received at a dealership.
Thanks again!
