Makes no sense... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-22-2011, 03:42 PM Thread Starter
Makes no sense...
I have a 2006 Ford F-250 6.0 Diesel.
I have an issue with losing throttle....drops to idle and stays there. I'm not getting any codes for this problem. What can cause this problem that wouldn't throw me a code?
When I first crank it up, it will run normally for a while (10 sec - 3 minutes), then I start experiencing problems with the throttle dropping to idle. Peddle does nothing. Once it gets to that condition, I have to turn it off and wait a while before I can get it to start again (I'm thinking it may be temperature based). the cycle then repeats.
I really hope to hear some opinions or ideas...please help
pearceyj is offline
post #2 of 4 Old 06-22-2011, 05:21 PM
Term3's Avatar
Quoted: 2 Post(s)
The go pedal is electronic and is not serviceable so my bet is that you need a new accelerator pedal assembly.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 4 Old 06-22-2011, 05:24 PM
mcflan's Avatar
Feedback Score: 9 reviews
Is there any hesitation on start up?
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Banks Monster Exhaust
Isspro Gauges
Studded, Lapped, and Bored
175cc Injectors
Powermax Turbo
Blue Spring FPR
Diesel Site Coolant Filter
AD2 Fuel System
Oil By-Pass System
My personally made Remote FICM/Board
mcflan is offline
post #4 of 4 Old 06-22-2011, 05:25 PM
Send a message via AIM to PowerstrokeTech82787
Ive seen this concern with e series ambulances for the app sensor not so much with F series and it could also be the egr valve sticking open enough to cause it to choke out on its spent exhaust.
PowerstrokeTech82787 is offline
