No fuel?
I have a 03 6.0, it started running rough, so I shut it off thinking I may have dirty fuel filters or water in the fuel, though I drain the water separator periodically. So I drained the water separator, now it won't start. Then I changed the fuel filters, and cycled the key about 12-15 times, and nothing.
So then I took the top filter off and noticed it was still dry from where I cleaned and changed the filter. So it's not getting any fuel. So does this sound like the lift pump went bad, or is there something else I need to check before I start pulling the tank? Thanks, Ryan |
You don't have to pull the tank anyway.
The pump is part of the HFCM which is under the truck, where you drained the water separator. |
check relays, fuse , plugs etc first.
10-4, thanks for the info, my last truck was a cummins so I was thinking the pump was in the tank.
I have a little more background for y'all.
Before I changed the filters, it would turn over and start, but would die as soon as it fired. |
Codes??????
No codes....
Do you hear the pump run when you cycle the key? Also pull your egr valve out and make sure that you don't have a chunk of carbon stuck in it holding the valve open. That's the usual start and stall issue.
I can hear the one under the hood, but I can't hear anything else. I'll let someone turn the key and I'll crawl under and see if I can hear the lift pump. Thanks Doc.
Has anyone ever had a fuel line get clogged up? We have tractors and have had them get clogged and had to blow them out.
The reason I'm asking is, when I took the old secondary filter out, there was some brown stuff around the edge of the inside of the filter housing. So could this indicate a leak in the fuel line somewhere? Also, even if the the EGR valve was stuck, would that keep the fuel filter bowl from filling up with fuel? |
