hey all, truck came in with blown out egr cooler, replaced that and oil cooler as per new egr cooler only lasted a year and two weeks that ford replaced
initially after i replaced it started right up but after shut off, injectors were not firing- listened to stethescope for click, but buzz test no problem. it sat a few days while i was on site repairing heavy equip, came back and started only once again then not again. checked all my work, tore down and redid it all, then no start at all. threw determinator on it everything checked out except injector control pressure. i believe when it was only starting up after sitting a long time icp was around 455psi, now about 147psi. ficm= good voltages, ficm sync=yes, cam and crank sync=yes, etc... i took out icp sensor and pressurized with shop air for about a minute with no loss of pressure or leaking noise. im pretty sure there is nothing i touched that has to do with the high pressure oil system at all right? just the low pressure oil system and while cranking the oil gauge acts appropriately. where do i go from here? i dont have a scanner all the time except for my buddys that i can use once ina while. i also hooked up a liquid filled gauge to icp port, cranked and got a bunch of nothing. hellllllllpppppppppp! Thanks, Phil |
everything is leading me to ipr stuck open? just removed it and has small hole in screen. about to disassemble it now
any input? |
You were not as clean as you should have been in the cavity where the oil cooler sits. That area must be SURGICALLY clean, especially the area under the screen.
Your IPR may have taken a hit. (as evidenced by the hole in the screen). My feeling is that if you have low HPO pressure, your IPR may have taken a dirt nap after getting nailed by whatever went through that screen. My suggestion? New IPR |
yes you are quite correct sir. also didn't mention the silly screen design under the oil cooler was torn through
when i opened her all up and put the new screen in there. that really aggravated me. im going to try and disassemble ipr cause i had found an article on how to do it but cant find it now
well watta ya know, as i presumed, the faulty hpop supply screen let debris into the ipr screen which tore a hole in it and had it stuck open. used a guide i found to disassemble the ipr and replaced screen, FIRED RIGHT UP! woo thanks guys for all the great info on these forums!
Nice job on your own repair of the IPR.
Care to share a link to that guide you used? |
sureeee
http://www.dfuser.com/Install%20Guid...0Regulator.pdf it was sketchy but i used good sharp pipe wrench on the threads and it worked perfect then just cleaned up threads with small file.the piece it says to unscrew with large flathead didn't unscrew but just pulled out with twisting motion. im really not happy with the design of the two screens ford uses, wayyy too delicate. coulda had egr and oil cooler done ina few hours but because the screen was failed it took much longer and a pita. im grateful because i've gained yet hours of training on my own of all sorts of things by reading thru this forum
