Sounds are driving me CRAZY!!! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-19-2011, 11:15 AM Thread Starter
Jeremy@TDA's Avatar
Quoted: 123 Post(s)
Help me out here guys! I believe I have a leak somewhere around my turbo but can't find it. Its like a sucking sound but yet kind of sounds like a squeel too. It does not vary with RPM only with turbo pressure. When i'm cruising about 55-70, I can ease into the pedal and the sound just gets louder and louder with the more boost it builds. I'm pretty sure its not on the output side of the turbo because I have absolutely no loss of performance or boost. What do you guys think?! I gotta fix it before I go nuts!
Thanks!
Jeremy
Jeremy@TDA is offline
post #2 of 9 Old 06-20-2011, 07:45 AM Thread Starter
Jeremy@TDA's Avatar
Quoted: 123 Post(s)
BUMP! Somebody help me out here
post #3 of 9 Old 06-21-2011, 10:52 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It sounds like the same noise I have, I finally climbed under my truck and tracked it down to a leaking up-pipe on the passenger side.
The flex joint has a split in it, if I poke a long screwdriver up to the flex joint and push on it the noise goes away, and I can also see some soot on the joint.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 9 Old 06-21-2011, 11:06 AM
information regurgitator
NYC F-350's Avatar
Quoted: 54 Post(s)
Jeremy;
Have you had the turbo off recently for any reason?
The source of your hiss could be the y-pipe to turbo connection. That clamp will NOT pull the connection together, much like you might think looking at it. That y-pipe must be fully inserted into the flange on the turbo BEFORE the clamp is placed onto the connection. Try taking that connection apart again, getting the y-pipe all the way into and square with the turbo flange, then getting the clamp on and tight.
If you can't get it to line up, your going to have to loosen both up-pipes at the exhaust manifold and gaining some "wrestle" room that way.
If you have not had the turbo out of the truck, or have not recently touched any exhaust component, then look at the firewall from under the truck. You will see soot around the area of your leak.
If it is coming from the turbo area, it could be a bad boost boot. Its the rubber boot right at the turbo connection to the intercooler pipe. The crankcase vent is in the tube just prior to the turbo, and the turbo action sucks the oil mist into the turbo. Then this oily mist travels throughout the entire air intake system. The silicone that the rubber boots are made out of degrade in the presence of oil. The crusty brown coating you see on that bright blue boot is actually oil that has been pushed through the boot from the inside of it and the dirt has stuck to that oil. That brown crust is telling you it is time to change the boot. The boot at the turbo tends to fail in the lower portion of it, right where you can not see it.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 9 Old 06-21-2011, 11:28 AM Thread Starter
Jeremy@TDA's Avatar
Quoted: 123 Post(s)
Thanks guys! The boot you speak of was replaced about 3 months ago during the head gasket install. Right after that install I got my new 2003 turbo that I put on myself. So I'm leaning towards the y-pipe connection you mentioned. I remember it being a ***** to put back on. I'll check that out tonight. As for the firewall, I checked that area the other night and can't find any soot at all.
Thanks!
Jeremy
post #6 of 9 Old 06-21-2011, 04:02 PM Thread Starter
Jeremy@TDA's Avatar
Quoted: 123 Post(s)
Ok guys here is what I found (and didn't find). My first observation was that the top of the turbo where the oil supply line attaches was damp with oil. removed the line and found that the gasket was torn badly. Apparently I didn't notice that I did that during install. So I now installed a new gasket. I dod NOT get to check the clamp for the y-pipes, because it was still hot as hell! But I did check around the area for soot. There is absolutely NO soot on or around (firewall) the flex joints of the up pipes from the manifold. However, there is soot build up on the firewall that goes over the top of the turbo, the turbo heat shield and onto the turbine side of the turbo. I initially thought this was from the bad gasket I replaced, BUT why would soot be coming out of the oil supply area? Any ideas guys?
Thanks!
Jeremy
post #7 of 9 Old 06-21-2011, 04:04 PM
NYC F-350's Avatar
Quoted: 54 Post(s)
It isn't.
Your y-pipe to turbo connection is off, and the soot is shooting in that direction.
Please
post #8 of 9 Old 06-21-2011, 04:17 PM Thread Starter
Jeremy@TDA's Avatar
Quoted: 123 Post(s)
I sure hope thats it. Tomorrow i'll take time to let it cool down for a while so I can check it. I have noticed that the noise is quiet in the mornings until after it gets up to temp. Steadily gets louder until i'm nearly to work.
post #9 of 9 Old 06-27-2011, 03:41 AM Thread Starter
Jeremy@TDA's Avatar
Quoted: 123 Post(s)
Fixed my leak yesterday guy! Although it wasn't were we thought it was. I had already gotten my tools out to take the y-pipe loose to check there and I notcied some soot build up in an odd spot.....on the back side of the vane solenoid! And it looked like it had be shooting upward towards the firewall that covers the turbo. So I grab my light and the first thing I see is HEAVY soot buildup on the bottom side of the bolt for the v-band clamp that holds the turbine housing on. I grab the bolt and try to wiggle the clamp....it's loose!! How does this happen?! i tightened the clamp down and all is good now! Thanks for the help guys!
Jeremy
