need write up for head gaskets - Ford Powerstroke Diesel Forum
Old 06-18-2011, 04:11 PM
Cool need write up for head gaskets
Hi all, new to this site and was wondering if there is a write up on head gaskets? I have a 2004 f350 with a 6.0L with low mileage and going to do studs, EGR delete and oil cooler and whatever else. It’s a nice time of year in New England to do a big job, better than the winter. I’m just going to remove the bed, jack the cab and drop it on the back of the frame to get it out of the way. Should be fun.
I have a ford manual and all data for 2005 but I don’t think it will help me, does any one know? I was just going to get all data for the 2004.
Old 06-19-2011, 10:12 AM
Send a message via AIM to PowerstrokeTech82787
Why would you put the cab on the back of the frame your creating more work for yourself. If you dont have a lift you can do head gaskets outside the cab just pull the front of the truck apart and pull the turbo off and pull the motor out...
IF you have a lift. Dont waste your time pulling the bed off.
Tools you will need.
1/2 in drive Impact gun
3/8ths mini air ratchet
1/2 in snap on 80 tooth flex head ratchet with long bar
1/2 in drive torque wrench
8mm 3/8ths semi deep
10mm 3/8ths semi deep
3/8ths extensions
T30 torx socket
T40/45 torx socket
13mm 3/8ths
19mm socket (2 nuts next to the radiator)
7/8ths socket cab bolts
15/16ths socket cab bolts
12pt 13/16ths or 11/16ths 1/2 drive for head stud nuts
Ok. 1st step, undo the belt tension, use a pry bar push the belt watch the tensioner walk and there should be a lock on the bottom push it in release the bar slowly and let it rest on the lock.
then use a thin flat blade screw driver and pop the shroud lock off.
Get the grounds 1 is on the fire wall going to the block remove it from the firewall the other goes from body to chassis under pass side door.
Get the shrouds out, drain radiator, remove the alternator the batteries, remove the radiator, undo the cab bolts, hook the a/c machine up evacuate the system, undo the pinch bolt 12 or 13 mm on the steering shaft, remove the hydroboost lines at the master, remove the master flop it on the intake, remove the heater core hose next to the alternator. Remove the pcm connector going to the ficm and thats about it off the top of my head. then the cab is ready to go up.
