Low oil pressure warning. - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-18-2011, 02:55 PM Thread Starter
After doing some major repairs on my high pressure oil system (see here Another no start (2005) I now have nothing registering on my oil pressure gauge. It was fine for a couple days, but now it won't come up. I pulled the oil filter to check if the housing was filling up during cranking and it does. From what I understand, by holding down the plunger, the housing should not drain. It won't stay full though. Am I correct in my understanding of this? If so, then it makes sense as all my oil pressure is simply being pushed through the drain valve. If not, any other suggestions?
'05 F-350 Crew cab XLT 4X4
6.0/Automatic
EGR and cat deleted, Insight CS, Sinister coolant filter, complete update kit.
Haze is offline
