P132B CODE
Can a bad or lazy VGT solenoid cause a P132B code? I just recently had the turbo cleaned and the VGT solenoid replaced about 3 months ago. The truck is a bit sluggish at take off. Is there anyway to check the solenoid to see if its bad? Thanks for any help.
any pre turbo exhaust leaks or post MAF intake leaks can cause this DTC. As can a sticking turbo, VGT, MAF sensor, MAP sensor, you name it
possible the turbo is sticking again I believe this code can be set if you haven't let the engine go through the VGT learn procedure also |
