bought truck changed oil no oil filter?????
Just bought 2007 f350 with 190000 miles on it when I changed the oil I found it had no oil filter what is the deal would that hide something
no oil filter, as in the oil filter housing is empty?
yeah that is correct same thing i thought
Wow, I didn't think that was possible.
Is there a bypass system on the truck?
I dont know about the bypass how would i know i just bought the truck now the truck runs rough after oil change and fuel filter change LOST
Is there a screw on type filter in the engine compartment or on the frame rail?
is there a large oil filter canister inside your front driver wheel well towards the bumper?
Just when I thought I heard it all.
I would think that the truck would run WORSE without the oil filter because the drain valve would not seal. In some cases an aftermarket oil filter comes with a new cap. This new cap is exclusively for their filter and is usually taller than the factory cap. A Motorcraft filter will not work properly with this cap and I suppose could cause issues?
