Well motor diagnosed with #5 cyl low compression with tapping noise like rocker arm noise. Will require heass redone and new head studs. I have seen on other posts that the Black Onyx gaskets are NOT the way to go. Any updates ? Thanks in advance
Before you spend a dime on parts, it would be best to have the cause of cylinder #5 being low on compression diagnosed first. If a roller lifter has failed, you're better off replacing the short block at the very least because the labour to repair such a failure will be expensive.
Thanks for the reply. Not being a mechanic myself I am relying on a shop here that has diagnosed the issue and says it is in the intake area with posibly a bent valve stem, or bad seat. The truck runs fine, but has a noise like asolid lifter motor with just one lifter tapping ??
