Question regarding stuck vanes - Ford Powerstroke Diesel Forum
Old 06-07-2011, 08:25 PM
Someone I talked to today said that stuck vanes can cause a no-start condition. Is that possible? I would not have thought that stuck vanes could cause your engine not to start. Maybe this person didn't know what they were talking about, but I sure would like to be sure.
Thanks,
Time2Live
Old 06-08-2011, 08:42 AM
I'm pretty sure mine were frozen in place just based by the carbon/soot shadow i saw when i busted it apart but mine started fine.
I'm still learning the intricacies of this motor but someone here will have the answer.
Old 06-08-2011, 09:15 AM
As far as at start I don't see the turbo vanes having any effect (benefitial or adverse alike) primarily due to the air pressure generated at startup / idle not being significant enough to cause any adverse affects. You'd most notice the issue at higher RPMs, WOT and acceleration due to higher RPMs = faster spooling turbo + turbo vane articulation = higher, or lower pressures given what position the vanes are stuck in.
In short, your turbo vanes not articulating should have no effect on starting your truck.
Old 06-08-2011, 11:15 AM
Yep seen lots of stuck vanes never have seen them cause a no start
Old 06-08-2011, 07:03 PM
Thanks for confirming what I had thought . Sometimes the obvious is not so obvious. I didn't think stuck vanes could cause a no-start, but I started wondering if this guy knew something that I didn't.
Thanks again,
Time2Live
