05' 6.0 is burping coolant.... - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-06-2011, 04:04 PM Thread Starter
I just returned from a 1500 mile trek across TX, dragging my 12K lb 5th wheel. On this trip I burned through 3 gallons of coolant, approximately a gal every 500 miles. There is no white smoke, only some evidence of coolant burping out the degas bottle. The outside temp ran between 95-108 deg, but my truck stayed at a pretty constant 208, minus a couple of big hills. I would normally blame the EGR cooler, but I just replaced the factory EGR cooler/oil cooler with a whole system from Bulletproof Diesel. My next guess would be head gasket, but I checked the oil sump and there's no coolant in there either. So what happened?
OKlunchbox is offline
post #2 of 10 Old 06-06-2011, 04:12 PM
degas tank cap?
HAM_RADIO_MAN is offline
post #3 of 10 Old 06-06-2011, 04:16 PM Thread Starter
Replaced it with a new one from Ford before the trip...maybe I should go back to the old one.
post #4 of 10 Old 06-06-2011, 04:20 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
headgaskets
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 10 Old 06-07-2011, 01:21 PM
I'm sorry but I think it is HGs also...
Former 6Leaker owner
Newman is offline
post #6 of 10 Old 06-07-2011, 01:59 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Gaskets are bad
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 10 Old 06-07-2011, 03:16 PM Thread Starter
Well crap! That was the one thing I was hoping it wouldn't be.
post #8 of 10 Old 06-07-2011, 04:24 PM
just curious, how do you diagnose the head gaskets being bad and not another problem? I know how to find out if it is the cooler but is there any way to nail down the gaskets being bad?
jaysequipmentrepair is offline
post #9 of 10 Old 06-07-2011, 05:22 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
to be honest, not really. you could test for combustion gases in the coolant but most wouldn't have the equipment (I've never seen it)
when you think about it there are only a few things that could cause the cooling system to overpressurize but only under load. when you rule the other things out (egr cooler or overheating) then there's nothing left
not to mention the obvious headgasket issue that already exists, it's a pretty straight forward diagnosis
ALSO! first and foremost, make sure you are not overboosting, you should not make over 28psi at any time on the stock tune. remember the 6.0 is loaded hot from the factory, any extra cylinder pressures aren't going to help anything
-Matt
2015 F-250 XLT 6.7L
post #10 of 10 Old 06-08-2011, 01:52 PM
I had the exact same issue, while pulling a 5th as well.... mine had no smoke either and it was HG.
ClutchR16.0 is offline
