cracked up pipe - Ford Powerstroke Diesel Forum
Old 06-03-2011, 02:30 AM
cracked up pipe
just got my truck back two weeks ago from the dealer. They installed arp's and a BD egr cooler. On my way home the truck started whistling again, and I thought oh great. Brought it right back to them and the tech took it for a drive and then smoke tested the exhaust. Definately a crack in my up pipe. They said they would have to order the pipe and they would call me when it came in. Two weeks have came and went and still no pipe. They told me it was fine to drive as is, but my fuel mileage has dropped 3mpg and the whistle is giving me a head ache. Is this going to cause any other damage having this leak. Thanks
Old 06-03-2011, 03:00 AM
I was told by a damn good tech to install an 04 up pipe they are better for the 05 - 07 trucks . I was told my baffels might be leaking cause i get a real foul smell from my exhaust . When the smell hits you it will make you turn your head and hold your breath,wierd huh. Does your truck have a bad smell on start up or at any point ? Have them put an 04 up pipe in there ...
Old 06-03-2011, 07:16 PM
definately smells bad when I first start it up. Wasn't aware there are baffles in the pipe. The sound is like a belt slipping but a hundred times louder and it is intermitent
Old 06-03-2011, 07:35 PM
information regurgitator
jay diesel:
Go pop your hood and while the engine is cold, run your hand around the turbo-to-y pipe connection. You want to run it around the turbo flange side of the connection. I bet thats your REAL leak. If your hand turns black, you know you've found it.
Tell me if this is a good description:
You will not get boost very easy and the hiss is so loud at times it sounds like a street sweeper. At idle it will be intermittent. A soft hiss and builds a little, then drops to nothing on occasion.
Old 06-04-2011, 03:17 AM
Originally Posted by NYC F-350 View Post
jay diesel:
wow, have you been driving my truck. That is a perfect description. I am going to check that flange today. If that is where the leak is Iam going to go postal two weeks with this obnoxious sound and they don't even need to order anything to fix it.
