head bolts
Anyone have any tricks for getting the last (closest to firewall) head bolt out?
03.5 excursion
die grinder ftw!
on the firewall?
can you get the bolt loose? if you got it loose but its to long to get pulled out then put vise grips on the bolt closest to the head (so the cut off end wont fall back down the hole) and cut it off then pull the rest of the bolt out and bingo problem solved. if you cant get a tool on it let me know so i can make a call and get you a solution.
nope cant get it to break loose
