having an issue po261 code - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-31-2011, 11:15 PM Thread Starter
the truck has been trowing the cel for like 2 weeks now randomly. its po261 cylinder#5 injector circuit low. i've cleared it a couple of times and it will come back to other random injector circuit low cylinders. i'm leaning towards the ficm. does anyone else have any ideas on this
thx
the80proof is offline
post #2 of 9 Old 06-01-2011, 09:05 AM
Quoted: 5 Post(s)
What year is the truck? Sounds like FICM voltage problem... Any other codes like PO601 for FICM performance?
a2elvis is offline
post #3 of 9 Old 06-02-2011, 02:07 AM Thread Starter
truck is a 2006. i havent seen the po601 code yet
post #4 of 9 Old 06-02-2011, 07:11 AM
Quoted: 5 Post(s)
Sounds like FICM problem check voltage
a2elvis is offline
post #5 of 9 Old 06-02-2011, 11:09 PM Thread Starter
i checked the voltage cold cycled the key i got 48v but it wouldn't hold 48v. it was steadly declining in voltage down into the 20s. not sure if thats normal or not.
post #6 of 9 Old 06-03-2011, 03:30 AM
diablos30's Avatar
Quoted: 31 Post(s)
no,not normal
diablos30 is offline
post #7 of 9 Old 06-03-2011, 06:56 AM
Quoted: 5 Post(s)
Nope should hold steady at 47-48 volts. If it drops to 20 that is most likely why its setting codes. Should be hard to start cold and maybe even run a little crappy cold. They can be repaired. I thought I heard on here that BulletProof is coming out with a FICM power supply soon.
a2elvis is offline
post #8 of 9 Old 06-04-2011, 05:32 PM Thread Starter
did another test on the ficm and it didn't drop under 47v. wtf now. this morning on start up ran like **** and POURED blk smoke for like a minuite or so
post #9 of 9 Old 06-04-2011, 06:17 PM
bad ficm for sure
potroloco is offline
