Missing when lugging... Had it scanned...
Hi ya....
2003 F-250 6.0 The truck missed when cold until warm up then as of late, after warm up in high gear on the interstate it's developed a miss... more so when your lugging the truck around. Took it to the local parts store and they scanned, didn't tell me an injector but the injector module? I recently changed oil and filters (including fuel) and it seemed to have gotten worse. I did put in some diesel kleen last night thinking maybe a sticky injector... your thoughts... (Even with a miss it still pulls better than my gas f-150) ![]() Im subscribed, any help would be appreciated! |
What were the actual codes? The Injector Module sounds like the FICM, which is a common problem with the 6.0L's. Measure the voltage cranking and while running. It should be 48v. Anything less and you have a problem.
I can't recall the codes themselves...
I will scan it again though. currently going to google the location of the FICM |
Its on the driver's side valve cover under the degas bottle (coolant reservoir).
Yeah, found it,
so far they say to test it, using a volt meter, black on battery ground. positive on the screw closest to the driver... Also, from what I understand on what I read, you install it and have to get it reprogrammed... is that right? |
Could you maybe post of a video of your miss while lugging?
actually,
I can, but I have to figure out a way to upload it... I'll see what i can come up with! compare it to a wet plugwire or a bad plug wire... shakes you out of the truck. |
Mine shakes at highway speeds sometimes, but I kinda thought it was my tires...Get a video quick! |
Iamthumbuppingaswespeak...
thats why no spaces!!!!!! |
