2006 FORD F-350 6.0l WONT START - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-30-2011, 01:41 PM Thread Starter
hELLO GUYS, WONDERING IF YOU COULD HELP ME OUT, MY 2006 F350 DIESEL IS MY SERVICE TRUCK AND IS CURRENTLY SITTING IN THE BUSH AT MY JOB SITE WITH A NO FUEL PROBLEM,
IT SPUTTERED A BIT AND SURGED AND WHEN I SHUT IT DOWN IT WILL NOT RE FIRE, IT IS GETTING NO FUEL THROUGH THE INJECTORS,
LAST SUMMER I HAD THE HPOP REPLACED JUST AS THE WARRANTY RAN OUT And they did the stc mod to the hpop. I have a edge evolution programmer on it as well and pulled the code P2285, replaced the sensor and connector, still no fuel, looked into the ficm and it is working propperly, any other suggestions, it will run with a snuff of heether and thats it. ( ps i am apprenticing under my dad to be a heavy equipment diesel mechanic and so far kinda ambarassed i cant get our service truck fixed) the nearest dealer is about 300 miles away)
thanks
TOPWHOP is offline
post #2 of 8 Old 04-30-2011, 05:54 PM
bondsman's Avatar
Check the connector to the icp sensor... It could be bad. Once you replaced it, cleared the codes, did you get any other codes.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #3 of 8 Old 04-30-2011, 06:59 PM Thread Starter
changed the connector at the same time as the icp, no start , no code, no fuel still
TOPWHOP is offline
post #4 of 8 Old 04-30-2011, 07:07 PM
bondsman's Avatar
Is the fuel pump working? What is the fuel pressure? If you suspect the icp? Unplug it and see if it will start. Other common free checks are the ebps on the driver's exhaust manifold, if it shorts, it will cause a no start/stall situation, you could unplug it and see if it will start. Try the same with the fan clutch connector.
bondsman is offline
post #5 of 8 Old 04-30-2011, 07:28 PM
What do you mean, and how do you know "IT IS GETTING NO FUEL THROUGH THE INJECTORS"?
Is there fuel in the upper filter housing, and can you here the pump run at first key on?
How about the lube oil level? Too high or way too low could be a clue.
What does "looked into the ficm and it is working propperly" mean? You measured the voltage and it was 48 KOEO, didn't fall below 40 while cranking etc...
How well does it run on ether, and quit using ether. WD40 will work well and without the whooof you could get with ether on an engine with glow plugs.
Cranking speed seem fine?
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #6 of 8 Old 04-30-2011, 07:52 PM Thread Starter
yeah the upper filter is full of fuel, the pump is running you can hear it, volt checked the ficm it was at spec, changed the connector and the icp, it was running started surging so I shut it off at the job site when I went to re start wont go.
runs good on a small amount of heether, I haven gave it too much.
also oil level is good, and seems to be cranking fine,
TOPWHOP is offline
post #7 of 8 Old 05-01-2011, 03:42 AM
diablos30's Avatar
Quoted: 31 Post(s)
check the ipr
diablos30 is offline
post #8 of 8 Old 08-03-2011, 05:41 AM
Not wanting to "Butt in". But I'm needing help bad having similar issue's with same truck "Except 250". I've tried to google a way to check oil pressure at the icp. all I found is about the adaptor. Well I went to a hydraulic hose store and bought a adaptor (12x1.5 to 1/8 npt ) to work with fuel pressure kit I rented from AZ. I have read that it will work on the icp sensor port as well for checking the 500psi start up requirements. But where do you get a gage that read up to 4000psi ? I've read about the air pressure test at the HPOP pump itself but if I get over 500psi at the icp port the ipr should be working right? I had the air intake pipe off and sprayed WD-40 and mine won't start on that. Oh by the way I did have 52lbs of fuel pressure. Need help Go reservation at beach next week. Would like to be able to at least pay for the fuel there and back. LOL! There was oil in the icp sensore when I removed it that is normal right?
Checked so far:
batteries individually--Alternator---unplugged icp---fan clutch---Ebp on manifold---fuel in bowl---wire chafing---fuel pressure--ficm just repaired last night with not seeing anything out of the ordinary---Oh I've put a little over 600 miles on it since a egr delete/ oil cooler mod.
sledgehammer800 is offline
