2003 6.0L Starter issues? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-25-2011, 01:47 PM Thread Starter
On this truck that I just bought, the starter seems to act weird. I can turn the motor over for 1/4-1/2 second, then it stops turning the motor and sounds like the starter is free spinning. If I let off the key and let the starter motor come to a stop, I can then turn the key and for another 1/4-1/2 second it'll turn the motor then will repeat the free spinning. Every 5, 10, 50 tries (ie: randomly) it'll turn the motor over for 5-10 seconds before free spinning again.
I'm guessing this isn't normal for a Powerstroke? Would this be a worn starter, or something else causing it to act like this?
billyrb is offline
post #2 of 8 Old 04-26-2011, 05:11 PM Thread Starter
anyone else have this issue? Is it a worn starter, or something else?
billyrb is offline
post #3 of 8 Old 04-27-2011, 07:28 AM
Feedback Score: -1 reviews
yes sounds like a starter. replace it with a factory ford starter. DO NOT put an aftermarket unit on it as more than likely you would be changing it again next year.
fordmasterdieseltech is offline
post #4 of 8 Old 04-27-2011, 07:29 AM Thread Starter
cool, thanks for the heads up. Wasn't sure if I should have it rebuilt by a local alt / starter rebuild shop, or just bite the bullet and buy a replacement fomoco.
billyrb is offline
post #5 of 8 Old 04-27-2011, 07:49 AM
either or, its up to you. definetly stick with a factory unit either way.
post #6 of 8 Old 04-28-2011, 03:17 PM Thread Starter
I guess since I'm going to be dropping in a ctd at some point in the very near future, might just save a few bucks and have this one rebuilt locally.
billyrb is offline
post #7 of 8 Old 04-29-2011, 05:55 AM
now were talking lol!! good luck.
post #8 of 8 Old 04-29-2011, 12:50 PM Thread Starter
Thanks. Going to go with either a 12v VE or P pump motor. I'm tired of electronics, sensors, PCM's etc. Would like the power of a VP44 motor, but don't want to screw with everything else at the moment. Hopefully the new software I bought will help me get the 6.0 back on the road so I can get a few more months of driving out of it.
billyrb is offline
