Rough running until it gets warm....Everyday.... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-21-2011, 05:23 PM Thread Starter
I have a 2006 f350 with 140k. I bought it with 115k a year ago and it seemed it has long cranking time but not a big issue. Last couple of months it has even higher cranking time but starts fine. Until it gets warm couple cylinders are not working. After it gets warm it just runs fine. almost perfect. In winter time (FLORIDA WINTER) cold starts were even harder. I thought fuel pump on the rail was bad and I just changed it couple days ago. But again same problem. Nothing changed. The engine has a egr delete kit and no things on the exhaust pipes. It doesnt have any cooling problem and oil pressure or turbo pressure is good too. Again when it is cold couple cyclinders are not working but after it gets warm everything is fine. Any ideas or opinions???
seerkann is offline
post #2 of 3 Old 05-09-2011, 09:16 AM
CEB
Mine was doing exact same thing and it was intermittent failure on the injectors had three of them actually going and replaced them and it runs like new again! Expensive but fixed the problem.
craigbright is offline
post #3 of 3 Old 05-11-2011, 01:57 PM
Chango's Avatar
check the thread in my sig for some possible help. good luck!
Awesome thread on oil / cold start issues for 6.0 ---->
Troubleshooting a no Start Condition --->
Still using Ford Coolant? ---->
Chango is offline
