04 f250 6.0 egr cooler problem
I have a 04 f250 superduty, started running a little funny and a little white smoke. had to get fuel, so i checked all the fluids, noticed the coolant was about 1 gal low, topped it off and drove home, approx 25 miles. Went to restart after shutting it down, just clicked a couple of times then fired, but ran real rough. noticed the coolant again was low, didnt drive it again, towed to ford dealer, they said that the egr cooler leaked into the intake and now they have a 6k bill to fix. injectors, turbo, egr cooler. has anyone had something simillar to this, not quite sure why i would have to replace the turbo even if coolant ran thru it, seems like you would just have to clean everything and replace the egr cooler that failed. please help..... thanks.
I would get a second opinion. If they aren't trying to sell you a oil cooler with the EGR cooler they don't know there 6OHs very well.
I would say oil cooler, egr cooler, and possibly EGR valve. Injectors could be damaged if engine hydrolocked and enough coolant made it past the rings and into the oil. I've had at least 4 trucks in the last year with EGR coolers bad enough to hydrolock the engine and I didnt have to replace a turbo or an injector on any of the 4. I would have them clean the vanes on the turbo while they had it off.
I had same problem on 06 350psd coolant was pukeing for bottle. under warranty my bud is service manager. Fixed the deal w/ new head gaskets and slide in erg cooler on side.also found a couple curved push rods. Hope you don't have to go t alone big pain in butt.
Mike n2pvo |
