REV-X.?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-02-2011, 07:02 PM Thread Starter
Brooks19's Avatar
Send a message via Yahoo to Brooks19
REV-X.??
can anyone give me a lil info on this rev x oil additive. have you guy noticed an improvement. i have slight engine misfire and a cylinder 5 injector circuit high code (P0274) and im thinking this may help?
EGR upgrade bulletproof
ARP Head studs
CTS insight
4in exhaust from turbo back
S&B Cold Air W/ CFM intake elbow
SCT SRL by Matt @ Gearhead
6in procomp lift W/ 37's
Brooks19 is offline
post #2 of 6 Old 03-03-2011, 06:05 AM
Quoted: 9 Post(s)
My truck was bucking real bad and low on power when I first started it and it would do it until the engine got all the way up to operating temp and then it would go away. Used some rev-x and next morning with no block heater and 28 degrees, it was a little better on initial startup, but within about a minute and the temp guage just coming off of the "C" everything cleared up. I would say it cleared up about 85% of my problem. It went from unbearable to acceptable. When I use the block heater, it cranks uup and runs perfect whereas it used to buck and jerk until it got to operating temp. 2 bottles.
divotf15 is offline
post #3 of 6 Old 03-03-2011, 08:19 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
IF your problem is injector stiction Rev-X will clear it up, period. If it is a hard failure it will not. Anyway the Rev-X is good for your truck anyway so drop a couple of bottles in and see what happens. It's cheaper than replacing an injector.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 6 Old 03-04-2011, 05:55 AM
scha0786's Avatar
Quoted: 24 Post(s)
tried two bottles myself, cleared my stutter on cold mornings. Good product and worth the 65.00
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
MBRP up pipe assembly
4" MBRP Turbo back (straight piped) WHISTLE
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
post #5 of 6 Old 03-04-2011, 06:47 AM Thread Starter
Brooks19's Avatar
thats for the responses guys! i think i might get my hands on some of this. everyone seems to think it helps!
ARP Head studs
CTS insight
Brooks19 is offline
post #6 of 6 Old 03-04-2011, 10:17 AM
It works, I documented it on Youtube. Too bad it's so expensive, and with the warmer months coming here in California, I probably won't buy anymore because I want to try 5w40 next winter.
2006 Ford F-250 Crew Cab 4wd XLT 6.0 Powerstroke Diesel
  • Rev-X Oil Additive and Archoil AR9100 Reviews(Check out my videos:
losbanosf250 is offline
