Truck Showing 3 CEL Codes - Ford Powerstroke Diesel Forum
Old 02-28-2011, 09:37 AM
Check engine light popped up today so I checked it with my CTS and its showing the following:
PO284-Cylinder #8 Contribution Balance
PO300-Random Misfire Detected
PO303-Cylinder 3 Misfire Detected
Also, truck has a bad vibration when the torque converter locks everytime. I was on a 146 mile trip and every time the converter locked around 40-60 MPH the truck starts shaking violently and I have to speed up and shift to 4th. Any idea what this could be?
Do I have to tear the motor apart to fix the codes? Injectors possibly? scorred cylinder walls?
Old 02-28-2011, 02:52 PM
helpppppppp
Old 02-28-2011, 04:55 PM
bummmmmmpppppp
Old 02-28-2011, 05:36 PM
Check compression first.
Old 02-28-2011, 05:42 PM
care to elaborate? compression of the cylinders?
Old 02-28-2011, 05:46 PM
Yeah by running a compression check you can determine if it's a mechanical issue or just an injector failure. You remove the glow plugs, thread in a compression adapter, and crank the engine over until the gauge levels off. Then compare all 8 readings in order to point out a bad cylinder.
Old 02-28-2011, 06:06 PM
I had cylinder #5 misfire and when my truck shifted to OD it bucked and jerked violently. When I mashed down on the accelerator it went away until it shifted back to OD. It was a bad injector! Its been fine since October.
Old 03-01-2011, 03:26 AM
i would check batteries and ficm voltage first. if they both check out then move on to testing the injectors.
Old 03-01-2011, 07:05 AM
my batteries are a bit weak but they are reading about 12.1 voltz on my gauge. It'll be going into the shop next week to see what the problem is
