Pulled out the EGR valve and....(any other suggestions while its appart) - Ford Powerstroke Diesel Forum
Old 02-26-2011, 07:51 PM
I was doing the normal matance today, oil change, and clean egr valve, and when I pulled out the valve there was coolant dripping off of it and coolant was all in the egr. So I stripped the engine to reach the egr and took it out and vacuum tested it with a vacuum tester and no leaks showed up. Cold it be leaking somewhere else? Also since I have the truck appart what else should i do in the mean time. it has a 109k miles, Nothing changed all stock.
Old 02-26-2011, 08:09 PM
285,261,190
chances are your cooler is shot. there should be no coolant on the valve or in the hole. if you do.......... sorry to say
Old 02-26-2011, 08:17 PM
delete it and replace the oil cooler while your that far in there
