how to control ipr? - Ford Powerstroke Diesel Forum
Old 02-26-2011, 02:02 PM
how to control ipr?
i want to pressure check my hpop. i have an auto enginuity scan tool....how do i control the ipr duty cycle
Old 02-26-2011, 03:07 PM
I found the icon on how to run the % up to 100%. after and during so i hear or heard no diffence in the air leak. seems equally as loud from filler cap and breather vent. it is an 05 with the stc fitting replaced months ago
Old 02-26-2011, 03:15 PM
are you having hot start issues? there are updated stand pipes/dummy plugs on the oil rails. the old ones are prone to leaking.
Old 02-26-2011, 03:26 PM
yes that is exactly the problem> i just changed the ipc,ipr, stand pipe and dummy plug on driver side in hope of a fix. after a ton of cold cranking it will start and die after about 15mins.
Old 02-26-2011, 03:35 PM
probably wouldnt hurt to replace the ones on the passenger side.
did you go out and do some wot runs to get the air out of the hpo sytem?
Old 02-26-2011, 03:42 PM
it wont run long enough...as soon as i touch the accle pedal it dies
