P0299 and P0470 codes - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-25-2011, 06:55 PM Thread Starter
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
2006 F-350, 6.0 with a 6 speed manual.. P0299 is an under boost code and P0470 is an EBP code. Can the EBP cause an under boost code and cause the boost to fluctuate 2-3 psi?
dhanna6powerstroke is offline
post #2 of 13 Old 02-25-2011, 07:02 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Yes it can. Step #1 is to access BARO, MAP and EBP psi data at key-on/engine-off. All three should indicate 14.3 to 14.5 psi (or whatever atmospheric pressure is in your neck of the woods). If any of the three are way outside of each other, repair as necessary. Are you getting just a P0299 and P0470 by itself, or are you getting any other DTCs (P0404, P2262 or P2263 for example)? If it's just those two, you likely have a faulty EBP sensor. As soon as the engine is started MAP and EBP should increase slightly, while BARO remains constant. A P0299 is likely caused by a sticky VGT unison ring.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #3 of 13 Old 02-25-2011, 07:07 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
Just the P0299 and P0470 codes. This is the no start truck you helped me with. Has been doing this since they got it running. I haven't seen the truck yet but he is suppose to bring it to me tomorrow. I'm installing an Insight CTS tomorrow as well.
post #4 of 13 Old 02-26-2011, 03:48 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
Removed the EBP sensor and tube. Tube had a lot of carbon build up. Cleaned and reinstalled. Still setting the P0299 code and now that I have driven the truck and seen it first hand, I can tell the unison ring is sticking. Anyone know the number for the updated unison ring and a price?
post #5 of 13 Old 02-26-2011, 04:31 PM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
post #6 of 13 Old 02-26-2011, 09:40 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Yes, that is the correct part number for the unison ring for ALL 6.0L diesels. But at that price listed in the link above, you may as well pick it up from your nearest dealer for the same or maybe even cheaper price than that.
m-chan68 is offline
post #7 of 13 Old 02-27-2011, 06:37 AM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
I was going to check with my dealer on Monday, just wanted to make sure that was the correct one. Thanks
post #8 of 13 Old 03-07-2011, 06:36 AM Thread Starter
Mod Newbie
Quoted: 20 Post(s)
Is there an actual part number for a 3M turbo cleaning kit? It shows a number on Diesel Technical Society (#03050) and that is supposedly an International number.
post #9 of 13 Old 07-13-2012, 12:30 PM
I'm having bad issues with mine.. I have deleted the egr system, rebuilt the turbo and new unison ring and solenoid, checked the tube on the map, replaced ebp and cleaned the tube... Still showing a 470 code.. Anyone have any suggestions.. I'm stumped and don't know what else to do.. It has now power.. The turbo is not acting right.. I can unplug the solenoid and it runs better but no power.. Plugged up it makes a hissing sound like the vanes close up and it will blow back thru the air filter..
Donnie11414 is offline
post #10 of 13 Old 03-20-2013, 12:48 AM
is there any help on this?
2006f350fx4 is offline
