no warm start - Ford Powerstroke Diesel Forum
post #1 of 29 Old 02-25-2011, 03:11 PM Thread Starter
no warm start
my 05 shut off driving and wouldn't restart. it did start the next morning and and ran about 20mins. only started once more after unplugging the icp. Any ideas? i do have codes p2289 p2285 u1900
va-fencer is offline
post #2 of 29 Old 02-25-2011, 06:00 PM
hp oil leak.
2006 cc 4x4,Rotella 5-40,Amsoil bypass filter Dieselsite coolant filter, edge evolution, K&N air filter, high idle mod, zoodad mod, 60 gallon Titan Tank, blue spring kit, Airlift 5000 bags, Bilstein hd shocks, MBRP 4 inch st pipe turbo back, welded egr cooler
rowcoach is offline
post #3 of 29 Old 02-25-2011, 06:42 PM Thread Starter
i have an auto eginuity scan tool and it shows 1500-1600ish psi while cranking. installed new ipc,ipr and dummy plugs passenger side cause it was easy, not because i heard any leaks
post #4 of 29 Old 02-25-2011, 07:22 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
STC fitting for the HPOP is pretty common on the 05+ trucks.
dhanna6powerstroke is offline
post #5 of 29 Old 02-25-2011, 07:41 PM
Powerstroke Techie
forddieseldoctor's Avatar
plug your icp sensor back in, clear codes, and then see what your icp voltage is. It should be between .15 and .35 volts key on engine off. It has to be a min of .8 volts while cranking for the engine to start. The p2285 code is more than likely from you unplugging the icp sensor. The p2289 code is defined as icp pressure high key on engine off. Could have been caused by a wacky sensor or by the oil that you found in the connector. Oil in the connector means that the sensor is failing anyway. As dhanna said the stc fitting is a very well known cause for this concern, however you should air test it with shop air, command the ipr valve closed and listen for leaks under the valve covers or the high pressure oil pump cover (where the stc fitting is located).
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #6 of 29 Old 02-26-2011, 02:33 AM Thread Starter
i changed the stc fitting to the new stlye 4 mo. ago. seem to get the 2289 code everytime i scan it. even after it is cleared. can i check the volts via scan tool? cause it have a voltage option, and it seems to be 4.25 while cranking.
post #7 of 29 Old 02-26-2011, 05:52 AM
Powerstroke Techie
Yes you should be able to watch voltage with your scanner. With that code I'm more worried about what the sensor reads koeo (key on engine off).
Meet Double Aught
2000 F250
post #8 of 29 Old 02-26-2011, 02:56 PM Thread Starter
it is only .25-.27 volts. it did start after a bit of cranking. then died as iwatched the icp pressure drop below 500psi. does anyone know how to control tthe ipr so i can pressure check the hpop? i wa told i could from the scan tool
post #9 of 29 Old 02-26-2011, 04:26 PM
Powerstroke Techie
I'm not familiar with the ae software.
Meet Double Aught
2000 F250
post #10 of 29 Old 02-26-2011, 04:30 PM
Mod Newbie
Quoted: 19 Post(s)
There is a wire from the IPR that you can supply 12 volts to and it will close the valve. I'll try to find which one it is.
