OK Diagnostic is back
These are the things that the dealership says needs to be replaced.
High pressure pump IPR Regulator ICP sensor HP tube Intake gasket set Turbo VGT Solenoid VGT Connector Can all of these things fail at the exact same moment in time? There is no way I can do all of these at once. Where would you start in trying to fix these issues? From my previous post. I lost all top end power, pulled over then began having no start when hot. Truck starts fine when cold. |
What year truck
I'm sorry..... 2003 6.0
i really doubt all of that went out at the same time....
I feel the same way. I just don't know where to start to figure out whats actually wrong with it.
where did you bring it to?
I took it to the local dealership
id would guess you have a oil leak.
How would you recommend going about finding the oil leak
While your at it thow in a LONG block
