No hot start low oil pressure - Ford Powerstroke Diesel Forum
Old 02-23-2011, 06:01 PM
Location: Greencastle, PA/ Marine Barracks Washington D. C.
Brand new ICP
Brand new IRP
Brand new HPOP
Still starts COLD just fine
Still runs great after started
Still won't start hot unless drifted or pushed
Still no codes
About 365 EOP when trying to start hot
Any ideas?
Old 02-23-2011, 06:09 PM
IPR orings... Could have pinched one when installing the IPR. Could also be the dummy plugs and/or standpipes leaking by when hot.
Old 02-28-2011, 02:22 PM
I dont think I have dummy plugs. Its an 03. I was under the assumption that 04.5 and up have them. I took it to a garage and they dont even know whats up with it.
Old 02-28-2011, 02:29 PM
i remember one of the techs talking about a possibility of the branch tubes being cracked, let me see if i can find the thread.
Old 02-28-2011, 02:34 PM
Powerstroke Techie
You need to air test through the icp sensor hole and close the ipr valve and see what leaks under the valve cover. If it's under the pump cover then you can blow air into the nipple that sticks up off the pump with a rubber tip blow gun.
Old 02-28-2011, 05:42 PM
Check the high pressure oil hoses under the valve cover.
