fan question ? - Ford Powerstroke Diesel Forum
Old 02-22-2011, 11:06 AM
fan question ?
for the last few days i have been watching my fan and notice that everytime i look at it its always on . is it suppose to always be on at idle ? its cold here -10 celcius roughly . did a datalog and eot and ect seemed ok . coolant was 186 - 190 and oil was 190 -198 .
Old 02-22-2011, 03:34 PM
anyone have any input ? i know its probably a dumb question but i just dont know .
Old 02-23-2011, 07:08 AM
Fan clutch can be locked up. Unplug the wire going to the fan housing on the upper left hand side then start the engine. If the fan continues to spin with it unplugged most likely your clutch is locked up. Also, behind the fan look and see if the bearing is pooching out the back. If so, again your clutch is toast.
Old 02-23-2011, 07:50 AM
fan clutch ?
so i unplugged the only thing i could find . what are the symptoms of a bad clutch ? i read somewhere that it is similar to bad HG's , is this true ? is this an urgent repair ? sorry so many questions , thanx deucer . IMG00191-20110223-1133.jpg.zip
IMG00192-20110223-1133.jpg.zip
Old 02-23-2011, 07:52 AM
i gotta unzip those pics i guess
Old 02-23-2011, 07:56 AM
pics of what i unpluggged .
Old 02-23-2011, 12:39 PM
What happened when you unplugged it? Start the truck with its unplugged. If the fan spins then it is likely the clutch locked up.
Old 02-23-2011, 12:41 PM
i unplugged the harness in the pic and started it again and the fan was still spinning . did i unplug the right one ?
Old 02-23-2011, 01:30 PM
Yes that is the correct plug, but hold off in replacing clutch just yet. With the engine off can you reach in and spin the fan? If so, it may not be bad after all. I believe the fan will have a free spin to it, but it doesn't mean it is actually engaged, meaning spinning at full cool. That is why I'm asking if you can free spin the fan with engine off.
Old 02-23-2011, 01:51 PM
Yep the fan spins with the engine, not quite as fast as the rpm but still enough to take a finger off. I think I read that if your turn on the A/C it will lock the clutch up and you will really hear the turbine.
