04 no start - Ford Powerstroke Diesel Forum
post #1 of 21 Old 02-20-2011, 07:19 AM Thread Starter
scotty2280's Avatar
04 no start
went to start the truck this morning and it wont start. icp is reading 380ish when turning over. im guessing its an o ring leak. im looking for more info if anyone can help out. truck ran just fine yesterday.
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #2 of 21 Old 02-20-2011, 07:29 AM
ajpu1983's Avatar
Whats your build date? Is it an 03 engine??
ajpu1983 is offline
post #3 of 21 Old 02-20-2011, 10:07 AM Thread Starter
scotty2280's Avatar
no its an 04
post #4 of 21 Old 02-20-2011, 01:14 PM Thread Starter
scotty2280's Avatar
tried unplugging the icp sensor and it was around 1600psi still no start. anyone got any ideas?
post #5 of 21 Old 02-20-2011, 01:29 PM
Powerstroke Techie
forddieseldoctor's Avatar
You could have a bad ipr valve, a blown o-ring, a bad hpop, the list goes on and on, However I am going to say that the 03 and 04's were not well known for high pressure oil leaks. However that does not mean that it's not possible, I would put air to the oil system through the icp sensor hole and command the ipr valve closed and listen through the oil fill pipe for the difference in air leak and make sure the valve is functioning(should get louder as you open it and quieter as you close it). Is your icp steady or really rough and spikey? If it's real rough and spikey then I would be more leaning towards the pump.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #6 of 21 Old 02-20-2011, 01:36 PM Thread Starter
scotty2280's Avatar
no its not spiky. it ran just fine yesterday with no problem at all. is the irp hard to replace?
post #7 of 21 Old 02-20-2011, 01:42 PM
Powerstroke Techie
Not too horrible, it can be done from underneath if you have the correct crowsfoot and a little patience, otherwise you have to pull the turbo to change.
Meet Double Aught
2000 F250
post #8 of 21 Old 02-20-2011, 01:55 PM Thread Starter
scotty2280's Avatar
does a scanner pick up the readings for the irp
post #9 of 21 Old 02-20-2011, 02:05 PM
Powerstroke Techie
There is no sensor to tell you if the ipr is moving. The only thing that you can see with the scanner is what the valve is being commanded to do.
Meet Double Aught
2000 F250
post #10 of 21 Old 02-20-2011, 05:10 PM Thread Starter
scotty2280's Avatar
i got the p2285 and a p2291 code. i might have got the 2285 code from when i unplugged it.
