Surge at idle - Ford Powerstroke Diesel Forum
Old 02-16-2011, 05:33 PM
Surge at idle
My truck has been surging since i got it a few months ago. Only did it rarely at first, but now it idles up and down all the time. I unplugged the ICP sensor while it was surging and it smoothed out. Perfectly smooth. I noticed a super lite coating of oil on the plug. Just replace the sensor right?
Old 02-16-2011, 05:41 PM
icp sensor
alot of times it is as simple are the wiring harness going bad. when surging condition occurs move harness wires around and see if surging stops. if it continues i would replace sensor, if it stops they sell replacement harnesses. I have a brand new icp sensor i would sell to you for 80.00 shipped.It is for 2004-2007 6.0s with production date from 7/19/2004 thru 12/18/06.
john
Old 02-16-2011, 06:23 PM
Jiggled the harness and it didnt help. I think the sensor actually leaks. I am gonna go to the dealer tomorrow
Old 02-17-2011, 02:39 AM
re
i wll ship the brand new sensor i have to your door much cheaper then the dealer will charge you
Old 02-17-2011, 03:10 AM
my truck was doing the same thing, brought it to the dealer and it found out it was caused by the cheap oil filter that I had used the last time I changed my oil. They put in a motorcraft oil filter and it was good to go. since then I am alot more caustious about what I put on my truck. Definately worth checking if you don't know what type of filter is in there.
Old 02-17-2011, 03:13 PM
napa filter is on there. I bought a motorcraft filter got it apart and realized what was up. I was in a bind and got another NAPA filter. I need a ford lid to go with the ford filter.
