DEAD HPOP? - Ford Powerstroke Diesel Forum
Old 02-14-2011, 05:54 PM
DEAD HPOP?
Just a question here, what the cr@p kills the hpop on a 6.0 dirty oil or factory stupidity? jw. Mine might be bad and i really dont feel like buying another cr@ppy part from ford.
Old 02-14-2011, 06:01 PM
Powerstroke Techie
What is the model year, mileage and maintenance/repair history of the truck in question? How has it been determined to have a failed high pressure oil pump?
Old 02-15-2011, 02:51 PM
its an 06 104000 miles, new turbo oil cooler, egr delete, oil changed every 3000 miles and fuel filters every 15000.
it hasnt been determined but thats what the tech is telling me it will probably be. it starts hard when cold and cycling the glow plugs makes no difference.
Old 02-15-2011, 02:55 PM
Powered by Deez Nuts
oil kills it
Old 02-15-2011, 02:59 PM
lets say it is a hpop that is bad where the heck can i get a new one that aint from ford? Dieselsite's arent out yet and they are supposed to be hopped up I just want a factory rated one if it is bad, and I change my oil regularly and use either powerstroke 10w30 or mobile delvac 15w40. Should I run a synthetic? And before I drop my oil to change it is it safe to run a can of seafoam through it. I used the heck outa that stuff in my big block.
Old 02-15-2011, 03:02 PM
Almostdunfukinwidit
Hard cold starts arent the HPOP normally.
Did the tech look at the truck or is he just guessing
Old 02-15-2011, 03:19 PM
Check your FICM, make sure it has 46 volts coming out of it. You have to check it from the top of the module with a volt meter. Directions are in the 6.0 forum
Old 02-15-2011, 04:06 PM
hes just guessing but Ive had alot of problems with these idi$ts. I read these forums everyday and I know more than those clowns. I think its the ficm but idk. I will check the voltage tonight.
