Engine Oil temp sender - Ford Powerstroke Diesel Forum
Old 02-14-2011, 02:26 PM
Two questions...
1. does it have the same thread as the EOP sensor which is listed #4 o-ring
2. why when I disconnect the engine oil temp sensor does my insight still register and read EOT??
Thanks in advance
Old 02-15-2011, 05:43 AM
The EOT and ECT are the same sensor and they are interchangable. That is actually how I check to make sure the EOT sensor isnt giving me incorrect info. I will switch them and see what my temps look like. If you disconnect the EOT sensor I think it should default to a preprogrammed value.
