06 Ford F350 6.0 KingRanch
Here is all the codes i get.
P0478 P0471 P0299 P0470 Here is the problem. The truck does no have enough power, the RPM's go up to 3,000. But the truck is moving really slow, I drove the truck for about 6 hours, and i got the power back it was getting a lot more then before, now it's the same thing, no power. It only reads up to 23-25psi. Turbo seems to work fine, it's loud like it should be. When i floor it and just goes really slow, and doesn't have that TD BAWR sound. I also cleaned out the EGR, EP sensor. Still the same. I changed the MAP sensor, still shows the code. It also starts shaking while going 45mph and 55mph No power just starts shaking>? Any Advice need it fixed. Thanks. |
Need help!
I see you cleaned the EP sensor. Cleaned the tube also?
Found this on another link. P0470=Exhaust pressure sensor Faulty sensor, open signal return, faulty PCM P0471=Exhaust pressure sensor range/performance Faulty sensor, restricted supply tube, faulty PCM P0478=Exhaust pressure control valve high input EP above specified value All pointing at the tube for EP or PCM 6.0L Diesel |
I cleaned everything i could almost, i just need to know how to get back my power. which code is causing this.
From another thread about EP sensors.
From moebdick: "Assuming that the EBP (EP) sensor is designed to linearly produce 0-5 volts between 0-54 psi, you should be able to test the sensor by removing it and attaching it to a compressor with a psi guage, then measuring the voltage output with a voltmeter. Each ±11 psi increase should result in a 1 volt increase." Could need a new sensor there. |
Showed 1 volt
1 volt, that means it needs to be changed?
Here is a comment by a diesel tech concerning the same issue as yours it looks like.
06 6.0 problems I had found some testing readings, but it was for a 7.3. Not sure if they would be the same, so I didn't post it. |
I will try and buy a EP sensor, and see from there.
Just read a thread about unplugging the sensor to see how it runs.
I had some EBP sensor problems last year and I was lucky and just needed cleaning. ? on ebp sensor - Ford Truck Enthusiasts Forums |
