6.0 Smokes and stalls at warm up
I have a 2003 6.0 powerstroke I just replaced head gaskets and egr delete. It starts right up no problem and little smoke when it gets warm it smokes more and when reved it smokes more. I just replaced oil rail to injector seals becasue I saw oil between there which I still do but is that where it is exhausted thru the top of the injectors? Any ideas it did not smoke like this before head gaskets and egr delete.
I ran the engine for a bit and I took a temp reading of the right side exhaust manifold and temp was around 180 degrees and the left side was all around 130 degrees. I am assuming that this has to do with either fuel or oil pressure. I am thinking that it has to do with a high oil rail pressure because at startup up with cold engine it runs smooth and little to no smoke. Within a minute it starts to smoke more and more and will stall. Any idea how to check and see where it is leaking? I see it coming between the injector and oil rail spouts but i think it is supposed to come up thru the injector where there are two holes in them.
