2005 Ford F350 6.0L: Wont Start!
I have a 2005 F350 that has 100,000 miles on it exactly. It will not start and sets the TBC ( Trailer Brake Control ) Light. Replaced the fuze because it was bad but the light still comes on. The truck will still not crank and Im beginning to think that its the injectors that are bad. Still will not crank no matter what. I even tried starting fluid and still no crank. It has plenty of oil pressure and I have it on a battery charger so it the batteries have plenty of juice. I honestly think that the injectors are bad. Any help is much appreciated! Thanks guys!
Trey M. Last edited by TreyM726; 02-12-2011 at 01:17 PM. |
Is it cranking but not starting or is it not cranking at all?
The truck will spin over just fine but it will not start up.. Thanks!
Do you have a way to monitor ICP pressure?
Could be your FICM...more likely than injectors.
FICM is more likely than injectors
Yes. The ICP Pressure is reading good!
Checking and repairing FICM -----> http://www.bscustoms.net/diesel/FICM.pdf
I took the FICM off of my friends 2006 6.0L yesterday and put on it. It still is doing the same thing unfortunately.
