Glow plug ???
2006 F250 KR 6.0
A little back ground. About a month ago my truck started with the typical cold start issues; rough start, white smoke (until warmed up). I checked the resistance of the GPCM harness pin points to the negative terminal on the battery. All readings were below 1.2 ohms. Harness had no bare spots and all connections were tight and clean. This morning I fire it up and during a short idle to warm up, a CEL appeared. Got it scanned and came up with the code P0677- Cylinder 7 Glow Plug Circuit Fault. Went to the house and re-performed resistance check on that circuit finding same aforementioned readings. As far as I understand anything below 5 should be fine. Maybe I am wrong. Any ideas? By the way this is my first thread. Thanks in advance. |
Ok, so I sure thought into this a little too much. Busted out the handy test light and found no continuity to #7. But hey, THANKS any ways...
Well finally was able to get my hands on a set of 8 ZD-13 Motorcraft plugs. Nobody here stocks them. Paid $11.49 apiece at a local Oreily's. Not as bad a job as I had heard and read. Took all of 35 minutes for the passenger side. 5 of that was hunting down the tools. 10 minutes for the inner fender well removal. 7.5 for the removal and replacement of the plugs.8 for the replacement of the fender well, and the last 4.5 minutes for a smoke and wipe down of tools and putting away the tool box. Not too shabby. Started it up a couple of times and the CEL went away.
Now for tomorrow the drivers side. See if I can beat my time.
Did you manage to remove the glow plug harness without damaging it? Just curious. On 2003 engines exclusively, the glow plug buss bar can be removed fairly easily without much, if any resistance.
For what it's worth, I've only ever had to replace ONE glow plug on a 6.0L out of the thousands I've wrenched on, that was ruined by a catastrophic EGR cooler failure...... ...... up until doing a set of head studs on a fellow member's truck with high mileage that had three out of eight glow plugs, that were above the 2.0 ohm spec. (including one that had ZERO continuity OL) about a month ago. |
Well, no. lol. The boots pulled away. Plastic was a bit brittle. For the time being. I set it up with some high temp RTV just to keep the elements out. It will work till I feel like buying a new one. Dont really see what is wrong with the fix I did. I didnt have a short enough extension so I had to improvise a bit. I used my 1/4n drive socket adapter for my screwdriver and deep 10 and a 1/4n wrench. HAHA! Worked great.
Follow up...
I have a CEL and the resulting P0671 (Cylinder 1 Glow plug circuit fault) code. Just wondering if there was a sure fire way to check if it was the connector/wiring or the glow plug itself. Thanks in advance for any help you may give. |
