Injector Replacement - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 02-11-2011, 07:53 AM Thread Starter
My #5 Injector has gone to lunch so tomorrow I will be tearing into the beast to replace it. Since I'm coming up to 250,xxx miles I would think there must be some worn out o-rings in there somewhere. Since it's going to be opened up, should I replace any? If so, which ones and what are their locations. This is for my early build 04.
Also, I assume the valve cover gaskets need replaced as well. However, it appears there is a upper and lower. I would assume I would only need the upper one but the geniuses at AutoZone don't have a clue. So, do they need to be replaced and if so, is it the upper or lower?
TIA
lugnut likes this.
2004 F-350 Crew Cab Lariat DRW
250,xxx Miles
K&N Stage II Intake, 4" Exhaust, EGR Delete, Studded
SCT LiveWire x/Canned Tunes
Boost, EGT & Trans Temp A-Pillar Gauges
Pioneer AVIC-Z3 SatNav, Rockford Power Series 6x8's w/ Alphasonic 2000 watt 4-Channel Amp. Viper 791xv Autostart, Keyless Entry & Alarm
The Repo Man!!!
MrWilkerson is offline
post #2 of 13 Old 02-11-2011, 09:17 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
At that high of mileage I would be doing all eight injectors along with the updated fuel pressure regulator from Ford. How many times do you want to be tearing into this yourself? As far as gaskets, the valve cover gaskets re-uasble unless you damage it during the repair. What you refer to as a "lower" gasket (which is the rocker arm carrier gasket) is accessible only by removing cylinder head bolts, so it's doubtful you will need that part.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #3 of 13 Old 02-11-2011, 10:57 AM Thread Starter
Thanks for your response. Just got back from the dealer....I will return the valve cover gaskets if I don't tear up the ones I already have.
As far as replacing all eight, the P/O for some reason had all except # 5 replaced just less than 100k ago. I just plan on replacing 1 at a time as need be.
When this injector problem first came up, I rented a fuel pressure test kit. At idle, I had between 64-66 psi and at WOT it would slowly drop to 58-59 and no lower. Would I still need the updated fuel pressure regulator?
Also, I picked up the new dummy plug while I was there. But now after reading more it isn't clear if I have one?
"In 2004 they went to a redisgned oil rail seen below. This oil rail setup has the standpipe going through the actual rail. Well in order to allow the same part to be used on either side they had to install a plug in the hole that was not being used by the standpipe. This is called the dummy plug."
So will I find a dummy plug in my early build 04? (S/N number & sticker on valve cover say 2003"
250,xxx Miles
The Repo Man!!!
post #4 of 13 Old 02-11-2011, 11:11 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Your truck likely already has the updated regulator in it, based on the posted pressure readings.
Then you can turn around and return those dummy plugs along with your valve cover gaskets because your 2003 engine doesn't use that. By the way, I hope you picked up a CN-5020-RM injector (which is the correct part number for 2003 engines), not a CN-5019-RM (late-2004 and up engines).
m-chan68 is offline
post #5 of 13 Old 02-11-2011, 11:26 AM Thread Starter
Why can't we have tech's in my neck of the woods as knowledgeable as you? I asked for the tech that works on the PS's and asked him that very same question. The pause and strange look he gave me right before he answered 'oh ya, the 03's have dummy plugs'. And then he brought be an injector box that clearly said 2004 and up right on it.
Are there any seals/o-rings/etc that I should service while I'm in there?
And thanks a million for the help!!!
250,xxx Miles
The Repo Man!!!
post #6 of 13 Old 02-11-2011, 12:16 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
None that will achieve any useful purpose other than emptying your wallet needlessly. Just make sure you lube up the new o-rings on the injector with clean engine oil or vaseline when installing it, and torque to TX-40 injector hold-down bolt to 24 ft-lbs. Overtightening it will achieve the same effect as not tightening it tight enough.
m-chan68 is offline
post #7 of 13 Old 02-12-2011, 04:51 AM
ajpu1983's Avatar
Yeah that's pretty bad that the PSD tech would not know that an 03 does not have dummy plugs. I might would check the connector for that injector and make sure none of the pins "backed out". I've had quite a few 6.0s that developed a skip that was because of one of the pins backing out and not making contact to the injector harness.
ajpu1983 is offline
post #8 of 13 Old 02-14-2011, 06:50 AM Thread Starter
Well, I got food poisoning on Friday and am just now recovering. I was going to drive the truck in to work today, but when I started it this morning it's not just missing every now and then.....that injector has completely quit working. I will check the harness when I get it tore apart but I bet It's out......seeing that it has 250k miles now...lol
250,xxx Miles
The Repo Man!!!
post #9 of 13 Old 03-01-2011, 08:25 AM
My Dream's Avatar
Any update? Have you removed the injectores from the passenger side? Is it a difficult task?
2003 Silver F-250 6.0L Auto, Lariat, 4x4, CC.
Zerex ELC coolant.....
Ford Air filter....
Banks Automind handheld running eco tune
Banks monster sport cat back system w/CAT delete pipe
Bullet Proof system, ARP head studs.
Pro Comp 4" lift W/MX6 adjustable shocks
35" goodyear Dura Trac tires.
My Dream is offline
post #10 of 13 Old 03-01-2011, 08:48 AM
diablos30's Avatar
Quoted: 31 Post(s)
replacing injectors on these is really not that difficult. its really just time consuming getting everything out of the way to get to them.
diablos30 is offline
