To Bulletproof or Delete? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 02-08-2011, 10:13 AM Thread Starter
Northwest Stroker
BigRed02's Avatar
Brought my Ex in to be evaluated for the leak its had for a few weeks and confirmed EGR cooler. I chose this shop while keeping that in mind because of the Bulletproof kit that he uses. He gave me the option sayin that the delete and the upgraded EGR cooler is fairly close in cost and labor is the same. He wouldn't give me a no BS answer on which one I should go with, so I'm turning it over to the more wise and weathered when it comes to going through this already and prob multiple times. I figured the EGR cooler has a job and why not replace it with a better one, thought I would go with everyones input first
2003 6.0L Ex Limited
Dieselsite Coolant Filter
Fully Bulletproofed
2002 7.3L F-250 4x4
AFE Stage 1
4" Turbo back Diamond Eye
Zoodad
Foil Delete
Auto Meter "Carbon Fiber" Gauges
2003 Suzuki M109R
Stock...for now
BigRed02 is offline
post #2 of 28 Old 02-08-2011, 11:22 AM
Carbon huffing animal
SixStringMadness's Avatar
If you don't have a tail pipe sniff test where you live, I recommend the BPD delete. It's what I installed in mine. The only way to tell that it's a delete is to sniff test it..... If you do have a sniff test, then the BPD EGR cooler.
ERIC - Tennessee Powerstrokes Chapter Director
2011 K1500 Silverado Z71 5.3L Vortec
2004 F250 Super Crew FX4 Powerstroke
1997 F250 Super Cab 4x4 Powerstroke
2004 K1500 Silverado Z71 5.3L Vortec
1999 F250 Super Crew 2WD Powerstroke ZF6
1998 K2500 Silverado 5.7L Vortec
SixStringMadness is offline
post #3 of 28 Old 02-08-2011, 11:22 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Feedback Score: 4 reviews
I am VERY happy with my BPD setup. I would go with the upgraded EGR cooler since it will be the same for labor and you won't worry about a check engine light for reduced EGR flow.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 28 Old 02-08-2011, 11:25 AM
03 - 04 don't throw codes for low EGR flow. and the BPD EGR delete is the same install as a OEM or BPD cooler.
post #5 of 28 Old 02-08-2011, 11:28 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Actually they do, they just don't set a check engine light. It's called a soft code. I didn't even realize what year his Ex was. Even still, I would go with the cooler.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #6 of 28 Old 02-08-2011, 06:34 PM Thread Starter
Northwest Stroker
BigRed02's Avatar
Great input guys thanks! Anyone have the BPD oil cooler?
Fully Bulletproofed
2002 7.3L F-250 4x4
AFE Stage 1
Zoodad
Foil Delete
2003 Suzuki M109R
Stock...for now
BigRed02 is offline
post #7 of 28 Old 02-09-2011, 06:00 AM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Yep, I sure do. What would you like to know about it?
Here's a pic of the cooler block
Air-to-oil heat exchanger
Upgraded EGR cooler
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #8 of 28 Old 02-09-2011, 08:07 AM
I deleted mine Dec 2009. Have put 35,000 on it since. I have no emissions test here in NH, so no problem there. Be sure to REPLACE oil cooler. After seeing what the intake manifold looked like. I was convinced it had to go! Engines should not be re-breathing soot!
dzlpwr1 is offline
post #9 of 28 Old 02-10-2011, 10:53 AM
I agree. I was glad to get rid of all that excess heat and soot, and the truck runs so much better without it.
post #10 of 28 Old 02-11-2011, 11:39 AM
sthomps's Avatar
Send a message via Skype™ to sthomps
My 05 has not set a soft or hard CEL since I deleted the cooler. Well mine is welded and the EGR valve is still in place and working, just not doing anything. Maybe it will set a CEL if the valve is removed.
05 F250 6.0PS 2WD Reg Cab
05 Escape 3.0 4x4
98 F150 4.6 5-speed
92 Lincoln Mark VII LSC
87 Mustang 5.0 Coupe 5-speed
70 Mustang Mach1 351C
sthomps is offline
