Pics of my project (not dialup friendly) - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-04-2011, 08:29 PM Thread Starter
Exclamation Pics of my project (not dialup friendly)
Too bad I cant figure out the no start or the coolant leak. I am convinced its fuel related but Ive decided to take the weekend off from working on it. Im too frustrated to think clearly and its too dang cold here so Ill re attack it next week. Im prolly gonna pull the cab again to fix the intake coolant leak but I really need to hear it run for some motivation first. 90% of all the work on this truck was done solo. I got help putting the heads on from a more experienced mechanic friend and he also helped me remove and replace the cab.
Caleb
TX Aggie 2012
Where I think the coolant leak is, o ring Ford sold me first and the source I think.
Random
And a pic of me so if you ever run across me in Aggieland say hi!
caleb2684 is offline
post #2 of 11 Old 02-04-2011, 08:55 PM
7.3powerstroke99's Avatar
sorry to hear about the truck. did you pull the cab because its easier than pulling the engine?
7.3powerstroke99 is offline
post #3 of 11 Old 02-04-2011, 09:01 PM Thread Starter
Yes sir. I spent four hours one day trying to get the turbo off and then I decided to take the cab off. Had the cab off in about 5 hours after I unhooked way too much stuff that didnt need to be disconnected. Sure made installing the new heads and studs easy! I had the cab re attached by myself in about two hours. I should have done the bare minimum until it started but you live you learn. Once it gets above freezing here again Im gonna pull her back off and try again.
Caleb
post #4 of 11 Old 02-04-2011, 09:10 PM
Ironmover's Avatar
If you believe your coolant leak is sourced from the O-ring you pictured, why in the world would you pull your cab again? That is if I am understanding you correctly?
Stock sucks
More torque pleeze
21st century participant of the 2nd amendment
Republican
Ironmover is offline
post #5 of 11 Old 02-04-2011, 09:20 PM Thread Starter
I think itd be easier than pulling the turbo and intake at this point, Ill give it a try though. Now that Ive seen every nook and cranny and know what to look for it may be easier. Thats the oring I mentioned the other day that sits under the intake between the water pump. I got to thinking today and the leak very well "could" be from the oil cooler cover. Its just too dang cold for me to care right now but I will keep you guys up to date.
Caleb
post #6 of 11 Old 02-04-2011, 09:28 PM
azkcr's Avatar
Quoted: 3 Post(s)
Hey man. I know of at least 3 more guys here in College Station that wouldn't mind helping you out/kicking a tire/drinking a beer/cussin' at your truck with you.
Shoot me a text sometime if'n you want 806-898-0167
-Ben (Class of 2012)
Ben Conner
LSP Assistant Director
Got every PSD made...
My DD: '13 6.7L with Optimus Prime's wanker still on the exhaust
azkcr is offline
post #7 of 11 Old 02-05-2011, 09:26 AM
Ironmover's Avatar
You have to remove that stuff anyways, I've had my turbo out 3 times, deleted the egr cooler and most recently rebuilt my oil cooler so I'm familiar with that little bugger. Not the most brilliant idea they could've come up with the coolers coolant return but I'm sure theres short cuts even to target that ring specifcally and be in there less than half a day.
Stock sucks
More torque pleeze
Republican
post #8 of 11 Old 02-05-2011, 04:48 PM Thread Starter
Thumbs up Shes running!!!!
and still leaking coolant... Good news was/is they were both caused by my hurry up stupidity and one is fixed the other will be on Monday!!! I had the wiring harness that goes to the fuel pump hooked up wrong. Then after removing the alternator and getting out my pocket mirror guess what I can see??? I somehow got that 80 dollar o ring out of the holder and pinched it inbetween the intake and the water pump. All I can say is that several lessons were learned and Im glad I did all this work myself in the end. Ill go get a new oring Monday and have it all back together soon. Im gonna pull the turbo and intake and not the cab for those wondering. It shouldnt be too bad now that Ive seen it all and that the bolts arent rusted in place.
Ben, yea man Ill give ya a shout sometime. Once the weather warms up, this global warming crap is killing me!!!!!
Caleb
post #9 of 11 Old 02-05-2011, 05:06 PM
Great job, I did mine myself with the Cab on. I took my time and like you had to fix a few minor things, but thats to be expected.
06 F-250 4X4
08 rear bumper and taillights,
Shaeffers 9000 5w40 don't use in your 6.0
GOGO direct solenoid, 08 tranny pan and filter
Edge CTS w/EGT probe.ARP 4" silverline,
fuel pressure reg upgrade, coolant filter, pre-pump spin on fuel filter, ELC,Oil bypass
SCT custom tunes by Vivian@QT and Matt @GH
4440 Front, 3040 rear, 7480 gross. VXCF4
worldwide73 is offline
post #10 of 11 Old 02-05-2011, 05:07 PM
97Beast's Avatar
Quoted: 13 Post(s)
Looks good. I remember last winter we had my neighbors 6.0l torn apart. Turned out to be a bad STC fitting. You definitely have no idea how much stuff is on those 6.0ls until you tear into one.
John
'97-F-250 PSD CCSB 3.55s E40D, Dana 60, PMF 2.25" RSK, U Code SD Springs, 315/75/16 TerraGrapplers, Tow Mirrors, Colibert Tow hooks, RDS Stage 1s, PHP 80hp, RiffRaff 6637, 3"DP, 4" Exhaust, 6" Tip, Power Front Seats, Rear 40/20/40, Explorer OHC and Autolamp Rearview, EATC, Cree LEDs & more
'89-Bronco 5.0l 33"s Free flowing exhaust, 06 SD power seats, & more (SOLD)
'80-M35A2 "Deuce 'n a Half" W/winch Multifuel Soft top
97Beast is offline
