Possibility of a reman inj being bad?
Hey guys, I just completed replacing 4 injectors on bank 1 in an 06 6.0L and one of the injectors came up with a performance code again? This was actually part of another thread I wrote the other day about the misfire and loss of fuel. Now, the injectors were replaced, the truck ran fine up until warmed up (bout 15 min) and cyl 5 came up with a performance code and a dead miss again. It will not come back even when cold now. I checked the harness, removed the FICM and resoldered all the joints after checking the unit for voltage as described in other threads (which was 34V during KOEO buzz test. the other 2 tests were within spec). The customer claims the FICM is less than a year old, but the date on sticker says 2005? Im now wondering what is the possibility of having a faulty injector? Of course, I know the possibility exists, but how common is it? I have to contact the dealer tomorrow to see what their warranty policy is. I have replaced probably 2 dozen of these in many different trucks in past years but never had a bad reman unit b4. Thanks for any input guys.
Rich,
Not sure if I have ever heard of it being a problem with some of my friends who are dealer techs or own their own shops. After you resoldered the connections on the FICM, does it check out at 48V? I would assume it does. Since you don't get any FICM related codes for cyl 5, I would agree that it sounds like a bad injector. |
this might be a long shot but I do agree the coil might have burned out in the injector with the low voltage... has this cylinder been dead for a while or did you just replace them all because you were in there...
Naa, I went in to replace a broken injector that was causing compression to leak into the fuel system. Right after I reassembled, the number 5 cyl came up as a bad injector so I replaced it and the other 3 as a precaution due to the history behind the failure. Now, the truck ran no more than 20 minutes or so and the injector on cyl 5 failed again??? It has a dead miss. I actually decided to remove and swap it with an injector from an adjacent cylinder. If the problem follows I know its the inj, if not then I know its an issue with the FICM beyond just the solder joints. I keep ya posted. Thanks for the replies.
I hope the swap works... if it isn't the injector I would agree there would be something wrong with the FICM... or one of the valves might not be seating correctly...?
Def not a valve train or internal mechanical issue. The truck ran great for that 15-20min test drive until it reached just about operating temp. I was decelerating off the highway exit ramp from a test drive and it started missing. IDK man? The customer tells me the injectors have all been replaced 2 times before. But, he also said the FICM was replaced and it has a 2005 manuf date on it??? That tells me its OEM Im guessing b/c the truck is an 06. If this is an injector issue. Im draining the fuel tank and telling him to find a new fuel supplier!! This is an F550 landscape truck so he gets fuel at the same place all the time and wont be taking long trips with this thing anywhere.
Update, I swapped injectors from cylinders 3 and 5. The problem stayed with cylinder 5. Therefore, FICM will be replaced. I know its not the circuitry, b/c I pulled what little hair I have left out trying to find any rubbed through points. None were visible. Next question remains, is there any way to have the FICM provisioned w/o the dealer having the truck in their possession? In other words, can the FICM be programmed outside of the dealer?
if you buy it from ford they will want the vin so they would flash it for you...
did you check injector harness for backed out wire on that injector? Also I would run a compression check to quickly assess the situation.
